My stats are not updating??
Rivethead
For some strange reason, my stats have been frozen for about the last week...well, technically, I'm falling behind as others are sneaking up ahead of me. My log file says that everything updates fine.....???
Any thoughts??? ....and, of course....many thanks to all!
Code:
[09:37:39] Completed 5000000 out of 5000000 steps  (100 percent)
[09:37:39] Writing final coordinates.
[09:37:40] Past main M.D. loop
[09:37:40] Will end MPI now
[09:38:40]
[09:38:40] Finished Work Unit:
[09:38:40] - Reading up to 516912 from "work/wudata_05.arc": Read 516912
[09:38:40] - Reading up to 971516 from "work/wudata_05.xtc": Read 971516
[09:38:40] goefile size: 0
[09:38:40] logfile size: 140906
[09:38:40] Leaving Run
[09:38:40] - Writing 1830378 bytes of core data to disk...
[09:38:40]   ... Done.
[09:38:40] - Failed to delete work/wudata_05.sas
[09:38:40] - Failed to delete work/wudata_05.goe
[09:38:40] Warning:  check for stray files
[09:38:40] - Shutting down core
[09:40:40]
[09:40:40] Folding@home Core Shutdown: FINISHED_UNIT
[09:40:40]
[09:40:45] CoreStatus = 64 (100)
[09:40:45] Unit 5 finished with 50 percent of time to deadline remaining.
[09:40:45] Updated performance fraction: 0.634549
[09:40:45] Sending work to server
[09:40:45] Project: 3064 (Run 3, Clone 218, Gen 19)
[09:40:45] + Attempting to send results [March 11 09:40:45 UTC]
[09:40:45] - Reading file work/wuresults_05.dat from core
[09:40:45]   (Read 1830378 bytes from disk)
[09:40:45] Connecting to [url]http://171.64.65.63:8080/[/url]
[09:40:53] Posted data.
[09:40:53] Initial: 0000; - Uploaded at ~223 kB/s
[09:40:53] - Averaged speed for that direction ~190 kB/s
[COLOR="Red"][09:40:53] + Results successfully sent
[09:40:53] Thank you for your contribution to Folding@Home.[/COLOR]
[09:40:53] + Number of Units Completed: 18
Correct Team and Name? Also, If memory serves it took a bit for my points to show up. Maybe a week or set threshold of points. Some reason 100k rings a bell.
yours should be updating, mine were from day one with the horde
mine too...I would definitely check your user and team number, once I accidentally put in brokenarrow instead of brokenarrow03 and [H]folding showed a new member of brokenarrow, so I didnt get a few pernts credited to my official user...
Unfortunately, that's not the problem.... the settings haven't changed, it's still the same computer - just the updates aren't posting anymore. Interestingly enough, I did have one post yesterday right after I put this up, but that was the first one in over a week. FAHMON tells me that everything is running right.... hmmmm....
Guess I'll just wait and see for awhile longer.
what kind of client are you running is it an smp client or vid card clients?
after i typed that in i figured it probably had to be the smp but was curious still if there were multiple clients and only one of them is getting threw or something? Also with a q6600 how often would it turn in a smp unit?
how does the win smp client do on quad proc utilization?
It's most efficient when run on two cores per client. For quads, it's best to run two instances at the same time, each locked to a pair of cores.
don't mean to threadjack here, but I'm using 4 cores on a smp setup on a q66. Could you give me a link that would point me towards running 2 like you say?
It's probably in the guides somewhere. I've never messed around with it myself so I can't give you any specifics. I now use the LinSMP client inside a VM instead of having the WinSMP client active, since it gives me much better PPD.
