My speakers buzzes with new LCD...!!
Boris811
Hey guys, i just bought an LG L1520B 15" LCD, and it's great, great colors, great response time, but something botters me..
Since i connected it, my speakers buzzes, and generally my sound is worse, because of that buzzing...
What could cause that, and what should i do.....?
I recently bought new wireles phone for home, and it's base is right next to the monitor, and mobile phones are next to it....
So, what should i do to prevent that buzzing, it's really annoying, besides that , great monitor.....
thanks....
have you tried moving the phones away from the speakers?
i know interferance often comes from mobil and wireless handsets. I doubt your monitor would cause a buzz in the speakers.
btw. i had a problem with a buzz before when i got an lcd and it ended up being a powercoard was shorting a little to the printer. Most likely this isnt the problem though
i had the same problem
so i disconnected all the grounds w/ cheater plugs
and now that everytning is floating there is no such problems
My speakers cable wasn't plugged in properly, that was making the noise ;) ;)......
Thanks anyway guys........
