My soon to be modded pc
mikeroq
Specs:
AMD Athlon X2 3800+ @ 2.4ghz
ASUS A8N32-SLI Deluxe
2gb DDR400 Dual Channel
XFX 7900GT 256mb
120GB SATA
80GB IDE
16x DVD+/-RW
16x DVD
6 in 1 memory reader
Creative XF-I Platinum
Happauge PVR500 Dual Tv Tuner
Windows Media Center 2005
MCE Remote
Pics: (more to come)
Going a little off topic. Is that 430 watt PSU I see there? If so upgrade that PSU!!! You have buttloads of components in there. You for sure need a stronger PSU.
Going on topic. Looks good. Nice specs. After some WM, that will look great.
Hehe, if it works dont fix it. Btw that PSU isn't bad, I've done some testing with it. Rails are a bit low but EXTREMELY stable. It's a rebranded 550w anyway, take a closer look @ the model number ;).
I have one myself. I will agree it isnt that bad of one. But he just has alot of components in there. Not sure how good that can be. If it works though under heavy gaming and stressing then I guess you got lucky and saved 50 bucks at least.
It does work its never failed in the 6 months ive had it, it was in my old rig. It is infact a 430w psu not a rebraneded 520 or w/e
Wow, this got off topic fast.
Anyway, you have a nice clean base to start with. What are your plans for it?
Well I have 2 planned upgrades in the near future.
Upgrade 0: buy some sleeving and zies and heatshrink, shorten psu cables, remove unnecessory ones, resleve and rewire, also sleeve other cables
Upgrade 1: Purchuse and install a GPU cooler and a new cpu cooler along with new fans.
Upgrade 2: PSU and another 7900GT
damn bro, nice set up and oc...
i have prety much similar set up as ur (except the mobo, ram branded, video card and psu), but i have tough time for oc. wat vcore do u set to? my x2 3800+ @ 2.4 @1.5v. and have to run ram @333. the moment i leave @ 1:1 ratio the whole thing wud crash and not stable for gaming. i used 3 psu so far and stil ahve problem with oc,lolz.. guess my chip is bad. nice stuffs bro and good luck of ur project dude.
You should paint the optical drive and the card reader to match the case, simple mod that I think would make it sleeker.
I am replacing those two components, with a new DVDRW and a floppy/card reader. also I will add some multi functions panels as well as my own
