Spec-
AMD 3800+ with Zalman 9500
250GB MAXTOR SATA HD
7800GTX 256 stock cooling
AUDIGY 2 ZS
TAGAN 530W EASYCON
Cooling-
Zalman 9500 on Minimum on fanmate 2
Yate Loon D12SM12 on Minimum on fanmate 2
Zalman 92mm on Minimum on fanmate 2
Worried about-
That the Zalman northbridge cooler is not getting enough airflow. My computer runs a bit slower in games.
The Zalman northbridge cooler is a bit fiddly, i can move it a bit if i jiggle it about.
Not enough airflow.
Too much stress on the tagan? The fan will have to work harder?
Cables on the tagan a little bent?
PICS-
General shot of the comp (Tried my best at cable management )
Vents on the side of the comp for airflow, no fans behind them
My silly Fanmate 2 cables, all hidden, will kind of
The Northbridge cooler
My silly attempt at dust filtering, still, should help
I apologise for the crappy pics, Im no photographer, Im better at painting or drawing things!
AUDIGY 2 ZS
TAGAN 530W EASYCON
Cooling-
Worried about-
Not enough airflow.
PICS-
