my sff build: (no overclock) pBTX
8steve8
1x aopen b200 pBTX chassis 275W $47
-pcie x16 riser
1x intel e6300 BTX T2 retail $220
1x intel BOXDG965PZMKR g965 pBTX board $129
-4x sata300 w/raid
-hi-def audio w/digital out
-onboard video capable of vista aero w/DVI (HDCP)
-intel GB ethernet on PCI-E
-pci express minicard connector
-4x ddr2 dimms
-1394a
-no overclocking. :(
Total system has 2 non-tiny fans... one in the psu (8cm), one in the btx type II thermal module that comes with the intel cpu (7cm). (tiny fans suck: break easy and inneficient in airflow vs noise)
still deciding on memory..
that is the only conroe cpu at retail available with Type II BTX thermal module intel retail. 3rd party modules can be loud and lower quality.. but if ur creative u can take that module and switch the cpu with someone for a 6600 (pay for diff)... which is what i plan to do...
case:
http://global.aopen.com.tw/products/housing/B200.htm
mobo:
http://www.intel.com/products/motherboard/DG965PZ/index.htm
(view available configurations and the one chose is there)
cpu:
no need for link.
i wish i could find this stuff at a better retailer... but page computers seem to have it all in stock... newegg and zipzoom dont seem to be into btx these days..
but if u can find a smaller system with these features and performance with less noise please tell me about it.
Where will you fit in all the hard drives? I only see room for 1 3.5 in HDD on the case specs....
i have used btx many times, usually type 1... they are great, no tiny fans, and the cpu gets fresh air from outside the case...
most people who dont like btx bought a 3rd party cooler which is not quiet.
dont mean to bump my own topic, but
does anyone have an aopen b200????
thoughts?
