Linkin Park
- Aug 29, 2002
I plan on buying a watercooling setup i thought i'd ask the pro's what they think of my current setup: this is all from the dangerden website:
RBX AMD
Maze 4 gpu Cooler
Danger Den 12 Volt D4 Pump, 1/2
Tygon R3603 1/2 Inch ID Tubing per Foot(5 Ft)
Clear UV Danger Den Single Bay Reservoir
Black Ice Micro II Radiator - Black, 1/2"(dual 80mm)
is this a good setup and everything. Will i need anythign else such as fittings or adaptors or is this it?
Also is it safe to transport your WC case if everything is bolted down casue i tend to go to a lot of lans and dont want to spring a leak. thanks for your feedback - mike
RBX AMD
Maze 4 gpu Cooler
