My setup, advice, critique welcome
botreaper10
Ok. I've had a bit of experience with water cooling kits before. I had a bigwater setup that decided to eat itself from the inside. I've learned from those mistakes and put this setup together. There is plenty of thermal dissipation for upgrades down the road. Don't mind the cable "management". I have a bit more work to go with tidying it up.
http://img.photobucket.com/albums/v140/botreaper10/SUC50883.jpg
http://img.photobucket.com/albums/v140/botreaper10/SUC50884.jpg
http://img.photobucket.com/albums/v140/botreaper10/SUC50885.jpg
http://img.photobucket.com/albums/v140/botreaper10/SUC50886.jpg
I wanted the heat to be removed from the case. So I mounted the triple 120 on the top of the case. None of the tubing is in contact with the case (sharp edges) since the connectors on the radiator protrude into the case itself.
As far as routing goes:
Reservoir/pump-->CPU block--->radiator--->reservoir.
When I add to the setup, it will just be after the CPU block.
Is the Zalman block an aluminium block? Just wondering how come you're not setting the tube it to the RAD then the CPU?
