Hi Guys
So I'm moving my NAS server to a rack, and moving from desktop to server hardware. It contains 28 hard drives.
I'm keeping the drives and the controller, and i already have 1 case and 1 SSD the rest i am getting now.
Edit: Will be using Windows 2008R2
Here is the config:
Case 1:
1x SuperMicro SC846A-R1200B
1x MBD-X8DAH+-F -B
2x Intel Xeon E5606, 2.13 GHz - Quad Core/1066/8 MB
2x Heatsink SNK-P0038P (Rev. A & B) 2U+ DP Server
6x Kingston DDR3 ECC Reg, 1333 MHz, DR x4, 4 GB
2x Intel 510 Series SSD, 120 GB, 450/210 MB/sec
1x SAS 4-port Cable Assembly, 68/76cm Supermicro CBL-0386L (For external to Case 2)
2x SuperMicro 3.5" convert to 2.5" hot-swap HDD Tray MCP-220-00043-0N
6x SFF 8087 to SFF 8087 Internal Backplane Cable, 39cm CBL-0108L-02 (To backplane)
1x Adaptec 52445 24+4 Ports RAID controller For case 2 + 12 internal drives
1x Adaptec 51245 12+4 Ports RAID controller for 12 internal drives including 2 SSD for system
4x SAS EL2/EL1 Cascading Cable (External), 68cm CBL-0166L (Between the 2 cases)
Case 2:
1x SuperMicro SC847E16-RJBOD1
31x WD Caviar RE4-GP, 2 TB, 64 MB, SATA II (So far)
After this i also have room for 20 more disks
EDIT: Now room for 24+45= 69 it will properly never be used.
So am I'm forgetting something or does it all look good?
EDIT: New case
Here is the config:
Case 1:
1x MBD-X8DAH+-F -B
Case 2:
EDIT: New case
