get the 940B, its a newer panel and will have better color.
KillerPotato said:I took the plunge and ordered the 940b for christmas. The prospect of backlight bleeding and dead pixels seems pretty terrifying, so I hope I get a good monitor. Anyone have any updated impressions on it? I'll post mine here when it comes.
Budwise said:i dont have any pics, but i have run a few games at 1024X768 cuz they didnt support 1280X1024. It looked pretty good for non native res IMO. Not as sharp as native res, but didnt make the game any less enjoyable if thats what you're asking.
gallatin said:Hey all -
I just got my 940b ten days ago. This review factored alot into my decision, so thanks for posting it. There is no ghosting in gaming, and the picture quality is amazing.
However, I was wondering if other 940b ownrs noticed a slight "droop" in horizontal lines on the monitor. This is something I have notied in 19 inch lcd's. For example, if you were on a mail site or forum with lots of horizontal lines, they would all slightly slag in the middle, creating a bended look to the page. This is more pronoucned when looking at the monitor from a lower angle. Looking at it straight on, it's not as noticeable.
Also, there is a slight uptick in the upper left corner where the explorer bar meets the actual webpage. I noticed this on Sony 19inch lcd's, and my samsing 940b, plus a few other lcd's at the store, from 17 inch to 21 inch. It's not quite uniform, something I was expecting from a flat panel LCD.
Also, text on the left side of the pciture seems to slightly scope down on an angle, and then on the right side slightly scopes up. I noticed this on numerous monitors at the store as well as my 940b.
Here are some examples taken from my monitor:
http://d43.yousendit.com/F/2XH50T3BPGAHA3IW4YT1U66W8Q/example pack.zip
Also, people have discussed light leaking on the top and bottom frame edges. I think that is normal for such a bright monitor. Turning brightness down to 25(the highest setting for alot of other monitors) gets rid of it.
Budwise said:Interesting. I just looked at all your photos and just to make sure i got a piece of photo paper and held it against the screen. Was perfectly straight in your screen shots and my screen... Maybe there is some sort of optical illusion going on? I looked and looked for the "uptick", but couldnt find it on yours or mine...
Budwise said:i actually realized something the other day. I reformatted my computer and never installed any calibration software and it looked great. I proceded to install Natural Color and as soon as i rebooted it threw the colors off so that i had to put them back so that it looked good again. I have now uninstalled NC, and everything looks great at default. Give that a try and see if that fixes your wagon...
NebulaD said:any other tips on adjusting the colors
Its driving me insane
Ill get it to look good for web pages but then I go to play a game and it looks bad so I have to adjust it again. rinse repeat
KillerPotato said:IRT gallatin
We wont be able to see your problem with screenshots. Youll have to actually take a picture of your monitor in order for the stuff to show up since taking a screenshot is showing what your video card would output, and not necessarily how the monitor would display it. So we're just seeing how it would look normally on our monitors.
IRT everyone else
What settings are you guys using in the calibration programs if you install them? I'll see what mine looks like when I open it on christmas, but it'd be nice to know what you guys have set up for me to try first.
Dreamsbetray said:u r using 360 on lcd did u download the patch 2 get 1280x1024 resolution or u r getting this resolution without the patch
