REDRIPPERNAVIN
- May 18, 2017
Tk for having a look. Hope you liked my build.
That is sexy as hell! Really like it!
Is the tubing flexible or rigid? If it's rigid, how do you manage to get the bends in?
Looks nice. Always wanted to do something like that but it's way too dusty here.. would have to spend more time cleaning it then actually using the computer.![]()
Is that the 600 be quiet case ?
GSkill FTW!
Nice build...you have WAY more spare time than I do....![]()
Nice, I look forward to the first set of genetically engineered AMD clones emerging from those axlotl tanks.
Be quiet dark base 900 pro
I have a silent base 800 but the 900 pro looks awesome.That case fan in the back looks pretty big. very nice build.
Irony is if you really love something you will sure make time for it. There is no excuse.
Looks really good. Are you going to tell us what components you've got in there?
Easy to say, but walk a mile in the shoes of others before jumping to conclusions. I work more overtime in a year than most people do in five. Some months is just work, sleep, work, sleep...scant days off are simply time to prepare the essentials for the next work cycle.
It's much easier to farm that stuff out than to spend that kind of time...![]()
It's a work of art.
Hmmmm, urine for cooling fluid. BRILLIANT!!!!!
Didnt mean to hurt you but the thing is wt i say doesnt apply to everywhone and if you want something you need to make sacrafice unless wt you are doing now is more important. I can never walk into your shoes since my life is different but life itself is a choice. If you made that choice that you shouldnt regret it.
Super duper nice build... I haven't read every thread response but would you mind sharing what this cost you? I am curious. It seems you went very very high end. And the price is probably reflected in the quality of this build. Thanks and only curious.
I am at the point now personally where I wouldn't spent not a penny on eye candy anymore. No one looks at my computer anymore. It just sits in my basement where I have a finished room that I use for VR, gaming, general PC stuff, surfing, movies, etc... no one ever comes down here anymore except my dog so paying for eye candy in my cases is just wasteful but yours is gorgeous.
Well you can totally avoid it but it would neuter any mods you do. I have my entire PC and my wife's in an air conditioned case. No dust and temp controlled for stable OCs year round. Power usage isn't too terrible for the setup but I also have a 8350 OCed so I said screw power usage a long time ago. lol.Dust is a enemy for any pc but if do it well you can minimize it but cant totally avoid it. I just configure all my radiator fans to exhaust that way i found minimum dust build up in my case.
Haha well if it does i think there is nothing to complain about it.Well you can totally avoid it but it would neuter any mods you do. I have my entire PC and my wife's in an air conditioned case. No dust and temp controlled for stable OCs year round. Power usage isn't too terrible for the setup but I also have a 8350 OCed so I said screw power usage a long time ago. lol.
