LightningCrash
- Dec 29, 2000
Slot 1 Celly 266@448, 192MB RAM
Hard drive blew a controller chip.
At least my Athlon 700s still work
my deepest sympathy for your lose. now it's in cpu heaven where it runs @ 1ghz with no heastsink.
What were you doing with it?
debian firewallWhat were u doing on a old comp? I know that isn't your main comp.
I was just thinking about slot mounted processors today. Whatever happened to that?
Indeed. Cache latency was too high on Slot processors IIRC. Plus the heat was getting harder to remove.they evolved....
Took the drive down. I might be able to fix the box, but at this point, I figure I might as well upgrade to something faster....so a harddrive controller took out the system...
Slot mounted processors came and went because of L2 cache.I was just thinking about slot mounted processors today. Whatever happened to that?
According to wikipedi there was a slot A thunderbird but I never heard of it being used in practice)
