my quest to build 1U server
DizzySHK
my quest to build 1u rack server
cpu cooler
Vantec CCK-6012(cools up to athlon xp 2000+)
$31.99
http://www.plycon.com/cpuc/van_6012.htm
cpu
Athlon XP 2000+(thorton core, FSB266)
$52.00
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-451&depa=1
Motherboard
DFI KM400-MLV
built in video, lan, sound, sata raid
$55.00
http://www.newegg.com/app/ViewProductDesc.asp?description=13-136-142&depa=1
Memory
Crucial 2x256MB DDR266
$92.00
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-001&depa=1
Case & PSU
Antec 1U case + 250W case
$259.00
http://www.antec.com/us/pro_details_rackmount.php?ProdID=94100
Hard Drive
??? 7200RPM 40GB
$50.00
Total
$539.99(w/o shipping and tax)
which brand of hard drive is most fit for a server?
i have searched everywhere for 1u cooler but that vantec listed above was the best i can find.
i would like to go higer cpu, possibly 2500+ as long as i can find the cooler. any good site
that sells 1u coolers?
If I was building a 1U server I would look at the 35/45 watt mobile Bartons and which Mobo they work the best in.
With around half the heat output they are a lot easier to cool.
So you may be able to run a faster CPU cooler.
Luck........ :D
