My Q6600 overclocking
sram
My other thread didn't get as many responses:( So here I go again:
Mobo: GA P35-DQ6
Cooler: Thermalright ultra120 extreme
I'm using the auto voltage optimization...........Is the voltage cpuz is reporting alright or is it a bit high?
Wonder if this auto voltage thingie increases the voltage for things other than my vcore! My RAM isn't overclocked
How about my temps....? I'm hitting 70 Max while in prime95 full load.
Idle is <50
I'm stable now at 3.2 GHz (ran prime for about 4 hours)
Will run it for more time later.
I would reseat your cooler and see if you can slightly lower temps (soem users reported the X that holds the cooler is a bit loose and put some tape underneat it to get a more secure fix) , but voltage read out is correct as it is also reported at 1.36 in Speedfan... isn't there a read out in the bios for all the chipset voltages ? so you can try eg all on auto, normal FSB then up again to 400FSB and see which values change... I prefer to set them all myself just to make sure some aren't overvolted for nothing...
