My puter is busted and I need help!
MacdaddyG
So, I'm not that good at troubleshooting stuff yet; I'm working on it. I have a POS computer, I believe it's the VIA KT800 chipset, 754 Socket A. I have an Athlon XP 2000+ processor with 1.5 GB of PC333 RAM, an 80 GB HD that has Windows on it and a 250GB HD that has everything else on it, and a Radeon X800XT vid card. Yesterday, my dog was around my PC, and it suddenly shut off; now when I turn it on, all the fans are running on it, but when I wait to hear the boot beep, it never does, and my monitor says no signal. I'm just trying to find out if my mobo went out or the vid card or what. Any ideas/suggestions you have would be greatly appreciated.
My first guess would be power supply. If the protection circuit has tripped you will need to unplug it from the wall to reset it and try again. If it still won't post remove/unplug everything except the video card, processor and one stick of ram. Reseting the bios with the clear CMOS jumper may help, it will erase any custom you have. If you were overclocking you definitely want to reset the bios back to defaults. If it won't post at this point it is one of the four items in front of you. Power supply, motherboard, video card or ram. If it does post then start adding components and see how far you get.
MacdaddyG said:
Yesterday, my god was around my PC, and it suddenly shut off; now when I turn it on, all the fans are running on it, but when I wait to hear the boot beep, it never does, and my monitor says no signal. I'm just trying to find out if my mobo went out or the vid card or what. Any ideas/suggestions you have would be greatly appreciated.
Maybe it's a sign to stay away from the computer... :eek:
Remove your video card and re-seat it. It could be that your...god....bumped it and nudged the video card loose. If that is the case, you may look into better ways to secure your video card. If the card is not screwed in...screw it in.
-hmh
I think he ment "dog" common mistake...
but we'll see if any external ethereal forces are causing this computer to go kaputz.
I fixed the god part... I plan on resetting my power supply first, then I'll reseat the vid card if that doesn't work and try different peripherals from there; who knows, maybe I just have a bad stick of RAM; puters are picky sometimes =/ I'll post again if I have any more problems and thanks again for all the help
I unplugged an reset the power supply and it booted up as normal. Thanks for all the help!
Isn't it nice when the simple fixes work. :)
I'm not sure how your dog could trip the power supply. I suppose if liquid got on it. :eek:
You don't by any chance have a funky smell coming out of your PC do you. :(
lol; no funny smells and no liquid on it; if the puter dies, I'll just part it out; I'm wanting to get a Dell or something, or maybe build my own, but it seems like getting a dual core Dell would be just as cheap if not cheaper than building my own (although like some other people I'm sure, I hate Intel and would prefer a 939 Athlon...)
Dell is going to use some AMD processors in it's servers, some time next year. Who knows, maybe some day you will be able to get a Dell with 939 Athlon.
