square pusher
- Oct 15, 2006
Yeh....
Ok so I bought my TRUEPOWER 2.0 from OC in may with my yearly upgrade in MAY, I was told to make sure and have a decent PSU as it is really the heart of the computer, I was reccomended the Antec TruePower 2.0 430W and it should be good for what I was planning on upgrading too.
So its been fine up until now, there is a smell looming around my room, I narrowed it down to my PC and I began to panic, with close sniffing I narrowed it down to my PSU. I blew all the dust out (without opening for warranty) and their was alot of dust to say the least.
It still brings out the smell, I cannot quiet describe the smell as I havnt really had a problem like this or I dont remember an electrical burning smell but it smells like burning of plastic. I have looked inside and cannot see any damage (although their is this white "stuff" around the cables to keep them in place and in some places it looks like it's been almost dripping, Im not sure if it was like that when I bought that or it is down to over heating.
Now I am unsure what to do, I do not have a replacment for the time being and I dont want it conking out and taking some other hardware with it! (althogh this is'nt meant to happen after some research it still does apprently!)
So whats the situation with this PSU? is it on its way out? is it dangerous? (my comp is on all day) and will I be able to get replacement or a repair from Antec for this?
I would appreciate help, I've done some looking up on it and it looks most of the time it dies, but I am just wanting to know my options and if I should be using the comp.
My specs are as follows:
AMD 64 3500
ASUS A8N-SLI mobo
2 gig 3200 RAM
ASUS 7900GT
180gig SATA2 HDD
1 PCI firewire card
2 DVD/ DVD RW
I think its also worth pointing out that it has been fine from may until now, I recently put in the 180 gig SATA2 drive and the PCI FIREWIRE card ( I upgraded the HDD from a 40gig IDE). So I'm not sure if this is the cause and I have exceeded the limit of power.
link to the PSU: http://www.antec.com/uk/productDetails.php?ProdID=17431
Thank you!
AMD 64 3500
ASUS A8N-SLI mobo
2 gig 3200 RAM
ASUS 7900GT
180gig SATA2 HDD
1 PCI firewire card
2 DVD/ DVD RW
Thank you!
