My project (Cosmos 1000 WC) new setup
Actual setup:
New Setup:
View Worklog: click here
porns not allowed on this website!
just kidding, looks sexy. Busy, but sexy
I just bought the Cosmos 1000. Originally I had the Raidmax Smilodon (which I don't recommend if your case is gonna be busy like mine is). I put it all together and everything is beautiful. I upgraded cases because I do want to do liquid cooling. My question for you is what brand of liquid cooling did you go with. I've been looking at a danger den setup which is fairly pricey. The other question I have is in regards to the optional hard drive fan that cooler master put in the cosmos 1000, if you have the fan installed in your system, which way do you have the airflow going? Currently I have my fan blowing air over the hard drives. Now I have been doing some thinking and feel i should actually have the air being sucked across the hard drives. What are you guys' take on this?
Sick setup you can take your whole entire loop and stick it any Case and make it look good.
Questions about your setup:
For item in red box:
1. How did you mount these side by side and what hardware did you use to attach to the side.
2. They are XSPC pump and reservoir correct?
kadozer even though this isnt my build and im not trying to mean or anything but the reservoir is right above that rather large cylindrical thing is the reservoir. :p allthough i could be wrong i am just going off of what is the picture forgive me if i am wrong. (and that is more than likely)
Yea that is the EK Multi Reservoir to be exact. I looked around and found it http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=22700
I thought it might be a reservoir/pump combo but its just a top or is it?
i honestly have no idea kadozer all i know is that there is a lot going on this guys case and it looks cool but its honestly to me too much.
Damn thats cramped in there.
EDIT: NVM it looks better, I skipped looking at the update because there was to many pics.
By looking at how you mounted your triple 120mm, it's inspired me to do the same with my 900:-D, with dual 120mm at the front!
