I was doing some work inside my case in an attempt to lower cpu temps. The main thing I did was remounting my TRUE with a new thermal compound (Shin-Etsu MicroSi G751) instead of the original AS5. When I finished, and was ready to push the power button, the machine couldn't fully start. It turns off right after all fans start spinning and it keeps doing this in an endless cycle. It seems to me that the cpu is overheating and the machine shuts down to prevent damage to it. Maybe but it can't get hot that fast, can it?
Sounds like I did a horrible job remounting! I did it many times, so why this time i'm Q@#$%# !?
I'll admit though I put more TIM than usual. I used the spread method. I spread it with my finger because it is thick. The layer is NOT transparent. Yes I can say that.
Is applying too much paste this bad????????
The cpu is overclocked so maybe if reset everything it will be able to start and let me see how temps are? Or should I just go and remount again?
If I remount, is it a must to remove all old paste and apply new one, or can I just try to remove some of it somehow and re-spread it and try to get a transparent layer?
All help is greatly appreciated. Thanks.
