My PC problems...conroe setup
vlotn7
When i first got my Conroe setup i had this problem where everything on my pc would turn on, but nothing would appear on the screen. Me being frustrated I set it aside and went to sleep. The next morning i put the setup back together just like i had before and wAlA~, it worked great. Picture and all.I played on it for about 3 weeks just fine. One day I went to replace my HSF to something other than stock. Then when i went to turn it on, I had the same problem that i had when i first got my conroe. I did the samething as anyone would have done in my predicament. I took all of the system apart, then put it back in, nothing showed up on the screen, no post, no beeps. Keep in mind all of the fans/hdd/videocardfans/ect cut on. I assumed my motherboard was dead, i got a replacement , that didnt help at all. same problem. I kinda think maybe something on my video card is fried, but dont know. I do not have another system to try any of the parts in. Any ideas??
7800gtx
e6600
GA-965P-S3
2gig corsair 5-5-5-12
I assume you tried a barebone setup with just the mobo/cpu/single.ram.stick/psu/vidcard plugged in, setup on top of a cardboard box? If so, did you try other ram slots, or the other stick of ram (try one stick with different dimm slots until it posts)? do you have a pci video card you can try? what psu are you using?
i have tried the barebones setup. i have tried different ram slots. MY psu is a 620 watt enermax liberty. I dont have another video card to try it with.
Try checking your RAM voltage, i.e. specs vs. what the mobo is putting out in the BIOS. I've run into similar issues with mobo's that max out at 1.8-1.9v and people that have tried to run higher rated ram modules in them.
i tried a different psu and graphics card, neither one the problem. I guess it has to be my CPU. There is no physical damage done to the cpu, i dont know if its fried.
