Yesterday, I got fed up with my PC acting up so I re-partitioned it. Cool. A fresh start. Not really.
I tried a new filing system but that messed everything up... so I re-partitioned again today. Bleh, now I have more problems then I did. When I go to install something, either from CD or download, about 10 times during the install I get this error message:
CRC error: the file <...> doesn't match the file in the setup's .cab file. The medium from which you are running the setup may be corrupted; contact your software vendor.
And I get three choices: Abort, Retry, and Ignore. Ignore skips the file but then the program never starts up; abort shuts down the installation process completely and retry never works... I just get the same error. I've tried installing Half-Life 2 from disc and get this problem and tried Roller Coaster Tycoon 3 and have the same problems. I downloaded 3 programs off the internet trying to get the programs back from re-partitioning and they get the same errors.
And then I somehow have a USB problem. Whenever I plop in a USB, it doesn't reconize it and doesn't run it/install it/install drivers. When I manually download drivers and install them, I either get the error message above or the USB still doesn't work. USB's I've tried: MP3 Player, webcam.
Also my ping has also been messing up since re-partitioning. I used to get 35-50 ping from anywhere (3MB Cable) but now can't get below 120.
I may be over-reacting and there may be an easy fix (that's where you guys come in) but I always get worried that something might be broken/chipped/burnt inside my PC.
Well, from eyeing these problems, do you have any tips/suggestions/ideas about them?
(P.S. I built this PC, good for about a year now... it's been fully functional, so support is outta the question.)
Thanks SO much in advance.
