newgamer22
- Sep 9, 2008
Hi, could you guys look over my setup let me know if it's ok, if not what should be changed. So far it's running good no problem. CPU under load stays under 70
Bios 907
Ai Overclock Tuner: Manual
OC From CPU Level Up: AUTO
CPU Ratio Control: Manual
Ratio CMOS Setting: 9
FSB Frequency: 370
FSB Strap to North Bridge: 400
PCI-E Frequency: 100
DRAM Frequency: DDR2-1016
DRAM Command Rate: 2T
DRAM Timing Control: Auto
DRAM Static Read Control: DISABLED
Ai Clock Twister: Light
Transaction Booster: Disabled
CPU Voltage: 1.3875
CPU PLL Voltage: 1.50v
North Bridge Voltage: 1.45v
DRAM Voltage: 2.10v
FSB Termination Voltage: 1.30v
South Bridge Voltage: 1.05v
Loadline Calibration: ENABLED
CPU GTL Reference: AUTO
North Bridge GTL Reference: AUTO
DDR2 Channel A REF Voltage: AUTO
DDR2 Channel B REF Voltage: AUTO
DDR2 Controller REF Voltage: AUTO
SB 1.5V Voltage: AUTO
NB LED Selection: NB Volt
SB LED Selection: SB Volt
CPU LED Selection: CPU VOlt
Voltiminder LED: ENABLED
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Bios 907
FSB Frequency: 370
CPU Voltage: 1.3875
DRAM Voltage: 2.10v
