- Jun 11, 2003
(didnt get any responses in my other post for some reason.... ???)
Pics (without base and no plexi)... =).
The only thing I havent worked out or at least started on is the CDrom bay area. I have a 4 inch LCD but need a power adapter, and I also need an idea of something to do with the cdrom. Im either going to stealth it or make a new front for my drive out of plexiglass and shoot a few LEDs through it.
Also, that gap in the first few pics between the front and the back is going to be filled with plexi. The top has a window for my 200g Seagate. It has a built in surge protector with 2 external ports for plugging in your monitor, etc. Wires are hidden to the best of the ability in this case, although I will do a bit of work before I throw all the plexi and such in there.
Dual 120mm intakes. PSU + dual 80mm exhaust (will probably have a 92mm on top, wont be too much work to add one in an hour or so of work if I get around to it).
Built in surge protector
