My next NES Mod
mattthemodder
I did the hub mod and I still had 4 Nes's left so.............
Im sticking a Saturn in a NES case, this is it so far
EDIT can't get the picture to work, you can see it at my modding forums here
I cut the posts off, stuck the mobo in upside down, so that the holes for the original video outputs can still be used. The PSU is going to be in a separte box, the four wires that goto the mobo from the PSU will probably be put onto some kind of socket and plug :D
The MySQL database is down. If it isn't fixed soon i'll upload the pic to a Geocities account
aww thats rather disappointing your going to have the power supply outside the mainbox, but its still a cool idea. Good luck with it :)
Originally posted by compslckr
workz now, where did you get 5 NESs?
i have 6 :)
had more, but got rid of a couple
they're so easy to get at goodwill
<3 goodwill
