Alright Guys Here is my next build:
MSI K8N Neo4 Platinum Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16813130484
NEC Black IDE DVD Burner Model ND-3540A - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16827152047
Seagate Barracuda 7200.7 SATA NCQ ST3120827AS 120GB 7200 RPM Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16822148039
Patriot 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model PDC1G3200+XBLK - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820220033
AMD Athlon 64 3200+ Venice Integrated into Chip FSB Socket 939 Processor Model ADA3200BPBOX - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16819103535
THERMALRIGHT XP-90C COPPER HEATPIPE HEATSINK
http://store.yahoo.com/svcompucycle/xp-90c-21.html
Panaflo 92x25mm High Speed
http://www.sidewindercomputers.com/pa92hisp.html
ARCTIC SILVER 5 THERMAL COMPOUND - 3.5 GRAM TUBE
http://store.yahoo.com/svcompucycle/as5-3g.html
ATI 100-435500 Radeon X800XL 256MB GDDR3 PCI-Express x16 Video Card - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16814102509
Ultra MS Blue Dragon ATX Mid-Tower Case with Clear Side Front USB and Firewire Ports and Ultra 500-Watt X-Connect Power Supply
http://www.tigerdirect.com/applicat...tails.asp?EdpNo=1419039&Sku=ULT30966-X-500-BL
I dont need a sound card cause i dont play alot of music.
Total Price After Shipping and Rebates: $1130
So what do you guys think?
