My next case... Hopefully
SpeedSlayer
Okay, so I wanted to do everything legally with designing this. So I downloaded GMax. I started 11pm worked till 2:30. I was done acutally at 2am, but spent a HALF HOUR trying to find a way to render finally i just got fed up with it all and screenshot it
To summarize that all
GMax = 3dMax - Rendering
No way to render for free except screenshot
So thats what I plan. I know the fault is in the tubing because around 1am, once i figured out the curving i just got lazy.
Tell me what yall think
EDIT:
Top Left Box: 2 HDDs on the bottom, 1 CDROM on top of it
Top Right Box: PSU
Bottom Left Box: Resevoir Pump
Bottom right box: Pump
Middle box: motherboard
light green tubes = water/clearflex
dark green tubes = copper or whatever else i figure out
This will all be done in aluminum... The only reason its transparent is to see the internals. The box that will hold the motherboard will ahve a window on top
The bottom two boxes will have leds underneath to show a glowing effect.
Each box will contain a exhaust fan. All control by a rheobus on the middle box.
A VFD will be also installed on the Middle box(on top, underneath, I DONT KNOW WHERE)
Wherever there is clearflex there will be a hidden UV LED shiney on that tube to give that droolable glow effect
It's possible to render with Gmax, just with scripts or something...
At 2am I didnt want to look for scripts. I was just looking for an easy way to click click click click -- "OOOH Pretty"
jeez that case looks frekin futuristic almost!
i like, nice job rob. thats alot like i pictured it :D
thats intense dude...i like it alot....are you gonna run the PSU leads through the tubes as well?.....what are the dimensions of the whole thing?
IIRC the measurments were 26" W x 10" H x 8" D
LEADS? huh
If you mean the acutal wires, yes thats what the dark green tubes are for, all the wires
