My new system....thoughts please.
TheRapture
It's long since I just cut -n- pasted...basically, RAID 0 on the SATA drives, 1gb of dual channel Corsair...
ANTEC Life Style Series Black Case With 380W Power Supply, Model "SONATA"
Specifications:
Case Type: Full Tower
Color: Piano Black
Material: 0.8mm SECC Steel
Drive Bays: 5.25" x 3/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2xUSB & 1xIEEE1394
Power Supply: 380W
Cooling System: 1 x 120mm Fans
Mainboard Compatibility: Standard ATX
Dimensions: 16.75"x18.25"x8.13" more info-> N82E16811129127 $99.99 $99.99
ABIT 875P Chipset Motherboard for Intel Socket 478 CPU, Model "IC7-G MAX2" -RETAIL
Specifications:
Supported CPU: Intel Pentium 4(Hyper Threading) Processors
Chipset: Intel 875P + ICH5R
FSB: 800/533MHz
RAM: 4x DIMM support Dual Channel DDR400 Max 4GB
IDE: 2x UltraDMA 100 up to 4 Devices
Slots: 1x AGP Pro/8X/4X, 5x PCI
Ports: 2xPS2,1xLPT,1xCOM,SPDIF In/Out,1xIEEE1394a,8xUSB2.0(Rear 4),1xLAN,Audio Ports
Onboard Audio: 6-Channel AC97 CODEC
Onboard LAN: Intel CSA Gigabit LAN
Onboard SATA/RAID: 4x Serial ATA, RAID 0/1
Form Factor: ATX more info-> N82E16813127152 $154.99 $154.99
SAPPHIRE ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
Specifications:
Chipset/Core Speed: ATI RADEON 9800PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz more info-> N82E16814102268 $215.00 $215.00
Intel Pentium 4/ 3.0C GHz 800MHz FSB, 512KB Cache, Hyper Threading Technology - Retail
Specification
Model: Intel Pentium 4 3.0C w/ Hyper Threading
Core: Northwood
Operating Frequency: 3.0GHz
FSB: 800MHz
Cache: L1/12K+8K; L2/512K
Voltage: 1.525V
Process: 0.13Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2
Warranty: 3-year MFG
Packaging: Retail box (with Heatsink and Fan) more info-> N82E16819116156 $230.00 $230.00
CORSAIR XMS Extreme Memory Series Low Latency 184 Pin 512MB DDR PC-4000 With Platinum Heat Spreader
Specification
Manufacturer: Corsair
Speed: DDR500(PC4000)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3-4-4-8
Support Voltage: 2.75V
Bandwidth: 4.0GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime more info-> N82E16820145458 $172.00 $344.00
Maxtor 60GB 7200RPM SATA Hard Drive, Model 6Y060M0, OEM Drive Only
Specifications:
Capacity: 60GB
Average Seek Time: 9.3 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: SATA 150
Features: Maxtor Shock Protection and Data Protection Systems
Manufacturer Warranty: 1 year
Remark: OEM Drive Only more info-> N82E16822144336 $85.00 $170.00
Viewsonic KU-306 Viewmate internet/multimedia Keyboard USB 104keys -RETAIL
Specifications:
Interface: USB
Number Of Keys: 104 keys + 15 function keys
Wireless Technology: N/A
Palm Rest: detachable
Design Style: standard
Mouse included: N/A
Features: Stylish, advanced design, two-tone office keyboard, Enhanced function keys more info-> N82E16823150006 $15.00 $15.00
SAMSUNG 193S-Black 19" TFT LCD Monitor –RETAIL
Specifications:
Panel Type: TFT Active Matrix LCD
Native Resolution: SXGA (1280 x 1024)
Pixel Pitch: 0.294 mm
Brightness: 250 cd/m2
Contrast Ratio: 700 : 1
Response Time: 25 ms
View Angle: 170° / 170° (Horizontal / Vertical)
Input Connectors: Analog HD15
Synchronization Range: Horizontal: 30-81kHz, Vertical: 56-75Hz
Dimensions & Weight: 16.9" x 17.0" x 8.0" (WxHxD) / 14.7 lbs
Manufacturer's Warranty / Phone No.: 3 years parts, labor and backlight / 800-726-7864
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY! more info-> N82E16824001150 $569.00 $569.00
Logitech MX300 Optical Mouse USB/PS2 -RETAIL
Specifications:
Interface: USB/PS2
Number Of Buttons: 4x buttons + 1x Wheel
Optical/Ball: Optical
Features: MX Optical Engine more info-> N82E16826104127 $29.00 $29.00
Lite-On Black 52X32X52 CD-RW Drive, Model LTR-52327S, OEM
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows 95/98/NT/ME/XP/2000
Features: Innovated SMART-BURN technology
Remark: OEM pack (see pictures for details) more info-> N82E16827106197 $33.00 $33.00
Subtotal » $1,859.98
if you're spendign that much, why dont you spend a little bit more and get a dvi monitor
