First I want to say, hello to all of you. I have been visiting these forums for a long while now but I just registered today.
I just built my new system, I have a few questions because I am getting some weird results from benchmarks and system monitors.
Specs:
Intel Core I7 920
EVGA X58 3X SLI Motherboard
2x Western Digital Velociraptor 300GB RAID0
EVGA GTX 295
Corsair Dominator 1600MHz Triple Channel DDR3 (12GB)
Corsair HX1000W Power Supply
Antec 1200 Case
The CPU and Video Card is water cooled.
Cooling System:
Swiftech Apogee GTZ CPU Waterblock
Koolance VID-NX295 GPU Waterblock
Danger Den/Laing DDC-12V 18 Watt Version 3.2 Pump with DDC Acrylic Pump Top
Koolance EHX-1320BK 4x120mm Radiator
Here is a pic of my cooling loop, the pic was taken while I was still leak testing, the pump goes over the bottom hard drive cage and I built a custom radiator stand.
My first question: Is there any problem with my loop? It goes to the radiator first then to the cpu, then video card then back to the pump.
My CPU temps are around 27-30C at stock speeds and I overclocked the CPU to 3.5GHz and the temps did not go up at all while idle. Everest is saying that my individual core temps are 45-50C under a full load at stock speed and the same at 3.5GHz. My 3Dmark Vantage score is 22,000 at stock speeds. My second question is, should I trust these readings and continue to push the CPU or is there something better that I can use for monitoring the temps. Also, 50C doesn't seem that good for a stock CPU with water cooling. Is there something I am doing wrong?
The last question, why is my Vantage score so low with this system? I see people pushing 30-40k with similar systems. Any insight would be a huge help. I am not new to overclocking and system building. I am fairly new to water cooling, and I don't really know what to expect out of a system like this.
Specs:
Intel Core I7 920
EVGA GTX 295
Antec 1200 Case
Cooling System:
