My new rig
Stroker
Im going to upgrade my computer and have been researching for some time now and heres what I have come up with:
Case- Silverstone TJ07
Processor- AMD Opteron 165 (OC)
MOBO- DFI NF4 SLI-DR Expert
Video Cards- SLI GTX 512s
PSU- Probably the Silverstone ST75ZF when it comes out
Memory- Corsair PC4000 DDR500 TWINX2048-4000PT 2GB
Sound Card- Creative X-Fi Fatal1ty FPS
Speakers- Logitech Z-5500 5.1
HDD- I have 2 74GB raptors and a 120GB Deskstar
I am planning on OCing the processor, GPUs and chipset with a
Danger Den DD12V-D5 pump
Black Ice Xtreme III radiator
some good waterblocks (haven't decided)
First what are your guys' thoughts on my system. Can I make any improvments anywhere? and second what kind of 3DMark 05 scores should I expect assuming I can OC the processor to approx 2.8GHz? I was thinking 14-15K? Or is that just wishful thinking?
yeh thats a good build...there are a few things to change but ill let the more knowledgeable ones tell you whast best...the only input im going to give is: get a bigger hard driver than 120 for your storage...because it gets filled quickly? i assume youre going to put the 2 raptors in raid and use them for gaming and the other one for music and storage? if so then get a bigger second hard drive.
also as a second note ive heard a lot of people saying that raptors are rip-offs and make no real difference in real world usage...you might want to consider that
otherwise it looks good
Drop the Raptors. Their speed isn't worth their limited size and quite frankly, not a huge improvement over most 7200rpm drives. For the same price you're paying for those, you could easily go with three 250GB Seagate Barracudas and more than quadruple your HD space.
I already own the 2 raptors and the 120. The 120 is for music and storage and is plenty for me right now. I did a format and installed a fresh OS on the Raptors 2 days ago and it was very noticeable how much faster it went.
you should get about 12k/14k
maybe 15k but i dont think any more then that... since two 7800GTs and 3500+ @2.7 only get 12700
