PrometheuSBoxeR
- Sep 21, 2005
Well I recently just put together the system in my sig. Everything seems to be great. Except for a few problems which mabey you guys can help me with.
First problem with my current rig Id' like to fix then i'll be happy.
1. Cables are everywhere and they need sleeves. I like my wires to look very organized and simple/sharp looking. I need some good recommendations of sleeves / cables basicly for everything.
2. Would like to consider using a fan controller, I used to use a nexus fan controller, mabey there are better. Id' like to consider my options for controlling fans.
3. DVD Rom and DVD Burner - How should I configure these to master/slave primary/secondary.
4. HDD partitions. I partitioned like 6GB to install OS and everything else is in the D: for my program files. Does this make any difference or could I just keep one partition of all 200gb? These seperate partitions kinda confuse me.
5. My MBM has a few 0C. In GPU, GPU ENV, and 120mm Fan, not sure how to fix these so it accurately gives me temps. Or suggest another temp monitor.
6. Backplate to my NV Silencer 5 Rev 3 on my 7800GTX is currently off. I idle at 43C and Load at 56C with my GTX. Still the memory on the backside. There is no way to screw it in, it supposed to be held on by ****ty thermal pads. Are there safe clips I can use to put it on, or any other way? Im sure it will help.
7. I also can't figure out how to run dual instances of prime95 when it comes time to, i'll need to.
8. Lastly - OVERCLOCKING : I have read most of the stickies on this site and other to figure everything out. But I am still confused on HTT/FSB/LDT/Multiplyers etc. There are so many calculations for follow... having little to no experience I am lost. I am looking to OC my VGA/Mem/CPU. Mabey someone can point me in the right direction please. Thank you
