I'm thinking that my next personal build is going to be AMD/ATI.
Which specific CPU and GPU did you have in mind bud?
OOOH, Magoo crossed over to the dark side!
I used to be an ATI fangrrrrl. I'm thinking that my next personal build is going to be AMD/ATI.
You can mount one of these Yate Loon 120x120x20mm low profiles fans in the lower chamber for HDD cooling. I have/had a P182 SE ( just switched all the components to a 1200), and I was able to put one of those fans in the lower chamber to cool my hard drives.
well i m using a P182 here and i can tell u that the Yate Loon slim fan will fit in the lower chamber but u need to remove the filter or else it will grind or stop the fan from moving... also it is easy fit and the model number for that fan is D12SL-12C/D12SM-12C
hope u will get ur P182 soon and enjoy it and post us some pic!![]()
You can check HDD temps w/ HDTune.If they're high, I'd suggest figuring out a way to mount a fan in front, instead of the middle of the lower chamber.
I have a Kama-meter and one of the probes is located down in the hard drive area. The temps stay around 38C, so I haven't bothered trying to fit a fan in the bottom. The other three fans in the system appear to be taking care of things.
