My New Computer Build
BWK900
Could you guys tell me if my new computer build on Newegg is compatible with each other?
A-Top XBlade Black/Silver Ultimate Gaming Machine With 450W PSU & Side window, Model "AT859A-BK" - Retail
Specifications:
Case Type: Mid Tower Case
Color: Black/Silver
Material: Steel
Drive Bays: 5.25" x 4/0, 3.5" x 2/5 (external/internal)
Expansion Slots: 7
Front Ports: 2 x USB2.0, 2 x audio
Power Supply: 450W
Cooling System: 1 x 80mm front Blue LED fan, 1 x 80mm side Blue LED fan
Motherboard Compatibility: ATX (12" x 10.5")
Dimensions: 17" x 7.9" x 17.3"(HxWxD)
Features: Side panel window with custom chromed XBlade design & a mesh guard more info-> N82E16811105113
$53.99
$53.99
CHAINTECH NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU, Model "VNF4/Ultra" -RETAIL
Specifications:
Supported CPU: Socket 939 AMD Athlon 64FX/64 processor
Chipset: NVIDIA nForce4 Ultra
RAM: 4x DIMM Dual Channel DDR 266/333/400 Max 4GB
Slots: 1x PCI-Express X16, 2x PCI-Express X1, 3x PCI
Ports: 2x PS/2, 2x COM, 1x LPT, 10x USB2.0(Rear 4), 1x RJ45, Audio Ports
IDE: 2x ATA 133 up to 4 Devices with NV Raid 0/1/0+1
SATA: 4x SATA2 3.0Gb/s with NV Raid 0/1/0+1
Onboard Audio: NVIDIA 7.1-channel audio
Onboard LAN: 10/100/1000Base-T Gigabit Ethernet
Form Factor: ATX more info-> N82E16813152049
$129.00
$129.00
MSI ATI Radeon X800 PRO Video Card, 256MB GDDR3, 256-Bit, DVI/TV-Out, PCI-Express, Model "RX800PRO-TD256E" -RETAIL
Specifications:
Chipset/Core Speed: ATI Radeon X800 PRO/475MHz
Memory/Effective Speed: 256MB GDDR3/900MHz
BUS: PCI-Express X16
Ports: VGA Out(15 Pin D-Sub) + TV-Out(S-Video/Composite) + DVI
Support 3D API: DirectX 9, OpenGL 2.0
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) more info-> N82E16814127155
$395.00
$395.00
AMD Athlon 64 3400+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
Specification
Model: AMD Athlon 64 3400+
Core: Newcastle
Operating Frequency: 2.4GHz
FSB: Integrated int chip
Cache: L1/64K+64K; L2/512K
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info-> N82E16819103484
$223.00
$223.00
mushkin Dual Channel Kit 184-Pin 1GB(512MBx2) DDR PC-3200, Model 991368 - Retail
Specifications:
Manufacturer: mushkin
Speed: DDR400(PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5-3-3
Support Voltage: 2.7V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Warranty: Lifetime more info-> N82E16820146379
$185.00
$185.00
Western Digital 200GB 7200RPM IDE Hard Drive, Model WD2000JB, OEM Drive Only
Specifications:
Capacity: 200GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: High-performance with 8MB Buffer
Manufacturer Warranty: 3 years
Packaging: OEM Drive Only more info-> N82E16822144129
$113.75
$113.75
Sony Internal 16X DVD+/-RW / Double Layer Drive Black, Model DW-D22A-B2, OEM
Specifications:
Write Speed:16X DVD+R, 4X DVD+RW, 8X DVD-R, 4X DVD-RW, 48X CD-R, 24X CD-RW and Double Layer 2.4X DVD+R
Read Speed: 48X CD-ROM/CD-R, 16X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2 MB
Random access time: 110 ms (CD-ROM), 105 ms (DVD-ROM)
Features: Buffer Underrun Proof technology
Packaging: OEM Bundle without software (see pictures for details) more info-> N82E16827131241
$58.50
$58.50
Microsoft Windows XP HOME Edition With Service Pack 2 -OEM
Specifications:
Designed exclusively for home computing. From digital photos, music, and video to building a home network, Windows XP Home Edition brings you into the digital age with ease. Built on the solid foundation of Windows 2000, Windows XP Home Edition also sets the new standard in efficient and dependable computing
*Must be Purchased with Hardware!!* more info-> N82E16837102151
$92.95
$92.95
Subtotal »
$1,251.19
Thanks
The CPU you got is a 754pin model, you need a 939 pin model to work with that mainboard. The 939 pin model does perform better due to the dual channel memory controller. So, get a 939 pin cpu like this:
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-463&depa=0
Just a few other notes..
I would recommend an SATA drive though, the price difference really isn't that much.
I'd also be a bit leary about that power supply. The cheap power supplies that come with those cases are not very good when it comes to longevity or high performance parts. Just something to keep in mind.
A good powersupply can be had from Enermax(my favorite) or Antec TruPower.
-Matt
Good specs, good post. You need a more solid power supply- the included one probably cost the manufacturer $5 :eek:
