My new Antec SLK3000B Case
Hot Sauce
Hi, I just bought an Antec SLK3000B Computer case. I have no idea what to do. Is there any way you can help me get things set up?
your first objective is to take good pictures of said case, and post in this thread. then, assemble your parts into it. if you run into a problem or hopefully, have to mod something!!! we will help.
I paid $64 Canadian before tax. Its so cool with air ducts and stuff ^^. My other one is so simple.. it doesn't even have air vents. Except in the back of course.
The store would've charged me $35 for installation, so I decided **** that. But now its so complicated inside, and it comes with these metal things with a whole bunch of screws and this metal rectangular prism in the accessories box. Its so complicated :eek:!
I'll take some pictures when I can borrow my dad's digi-cam.
judging by that last post i would either take it somewhere and let them do it,
or study up on installing parts in a case.
its not really taht hard, just make sure your grounded all the time
my basic order is psu, board, cpu, ram, pci cards, hdd and cdroms, then clean up the wiring
By rectangular metal prisms, do you mean in the 5.25 inch drive bays? If so, this is the thing that confused me when I first got one. To remove them and install your DVD/CD drives, you will have to remove the entire plastic front of the case to get access. There are small black latches just inside the front of the case for this purpose.
I think I'm going to shop around and see what stores will help me out. By the looks of it.. it seems like theres no way I could even try to do it w/o damaging something. But thanks alot guys, you're very helpful.
