Silent Assasin
- Aug 1, 2004
Ok, so I just made the deal of the year for me. Last weak I won a used 24 port switch from Ebay for $30.20 shipped. I didn't find it untill about 10 minutes left on the auction so I didn't have much time to look it up untill after I won. It's a Netgear FS 524, 24 port switch.
But anyway, it finally arrived today and I plugged it in to test it out. First thing I noticed is how loud the fans in the back are.... There are two fans that are around 1.75" tall sitting in the back... Because of the size, they are really loud. I know that it's main intention was for a rack mount, but my main use will be just sitting ont he top shelf of my desk and it will also be used as my portible LAN switch. So after testing all of the ports, I opened up the casing to take a look inside. For a used switch, it was very clean inside. But anyway, the two fans are connected to 2 different 2-wire ports on the mainboard. Now I was wondering if it would be possible to take those two fans out and cut a whole inthe top to fit an 80mm fan with a steel gaurd. Or I might even be able to fit a 120mm fan up there. How hard would it be to wire a fan to work with the power supply? It would be nice if I could get a 120mm fan and run it at 7v, but I'm not sure how the 2-wire plugs work..... On the back, next to the power plug, the specs are 100-240 VAC, 50-60Hz, 0.75A max. There are no other power specs on the casing or the fan.
So would it be possible to run a regular 120mm fan at 7v on this thing?
