My network consists of a couple of PC's and laptops, XBOX.
I have a switch Netgear 608v2 (all 1Gb) that connects the wired clients. I have an access point WDNR3700. I started out trying to find ways to improve the wireless performance for my XBOX that works as a media extender. At some point I had the intuition to connect the XBOX to a wire. This caused a surprise as the XBOX-MediaCneter network analyzer shows a less than perfect performance.
So, I tried to isolate the issue. I ended up switching of the access point and disconnecting clients. I ended up with one test case where the Win7Box with MediaCenter, XBOX, and one XP client PC is connected. Still having issues. Plugged out the XP box -> network was fine. I do not think that the single XP box is the issue. I saw similar effects switching on/off the access point.
I'm somewhat at a loss. One the one hand it seems to make sense that more clients will degrade the network, but not by that much (idling clients).
I wonder if any of the advanced network option in the adapters could cause the issue. There is always a large list of other check boxes other than the TCP/IP driver. From QOS, to deterministic network enhancer,...
