Ok guys -
Came home from work. Computer was on since last night. I saw that Symantec Antivirus had quarantined some items...(dont remember what they were).
Internet was working (I was downloading a torrent file from eztv.it)
I rebooted the computer...
After a very slow reboot (stuck on LOADING YOUR PERSONAL SETTINGS for at least 2 to 3 minutes) I got 3 pop-up warnings:
1) a microsoft pop-up: yzz.exe has encountered a problem and needs to close.
2) a Symantec pop-up: Symantec email proxy cannot scan your email messages because your network is not properly configured (actually two of those popped up).
3) another microsoft pop-up: No firewall is turned on.
I cant connect to the internet.
I can't connect to my Network drive.
I did a FULL virus scan and revealed nothing.
If I try to change the firewall settings I get:
Error: Windows cannot start the Windows Firewall/Internet Connection Sharing service.
The Firewall has been stopped. If I simply click the icon in the tray, it will take me to the Windows Firewall settings page. I get the red warning that the Firewall is off and when I click on recommendations, it says:
Windows Firewall cannot be started. Try to access from the control panel.
When I go tot he control panel, I get the same problem OR I get a wanring that the Firewall / Internet Connection Sharing Service cannot be started...
If I go to the Windows Task Manager I get this:
NO ACTIVE NETWORK ADAPTERS FOUND
If I go to a system restore point - the only point I see is the last time I logged onto the computer. All other restore points and dates are GONE.
Any idea what the h3ll I did?
