make sure the inverter supports dimming, most do not
Thanks for the heads up but these are led's, and I already have a potentiometer that I've found to work quite well with it. I just need to find one in the right form factor to blend in well.
Probably the sexiest looking computer I've ever seen.
Blue Aqua,
Like others have said...beautiful job and excellent attention to detail.
Absolutely love the way you set up the tubing. I've done this in the past using 7/16" tubing on 1/2" fittings with no clamps. On my new build I was just going to go with 3/8" and compression fittings, but I like the way you did this enough to change my mind. I read in your thread over at XS you used 3/8" tubing, but I didn't see mention of the fittings size you're using?
Best,
Liquid Cool
