my modded power supply
flow207
ok, heres my power supply that i just recently got done modding(well maybe). its the turbolink that came with my case. i dont really have pictures of it before i started but it just looked like a
normal PSU.
thats basically right after i got done cutting. i decided to go with 3 holes and paint it black.
thats after about 2 days of painting and sanding. and at like 4 hours of cutting the plexi and chopping up the inside. i removed the black fan and replaced with a red LED fan i had sitting around (luckily it worked)
about the best shot of it i could get in my case. i learned one thing with this. plexi is a pain to work with. im thinking i may cut out the fan grill and put something different there and possibly put another window in the opposite side, and paint the rest black.
(update: resized pictures)
-morgan-
Props for the whack 'n hack of the PSU. Makes my stock one look shameful! Very nice cutting also. Did you use a dremel? Jigsaw for plexi?
i just used a dremel for all the cutting... the hardest thing with the plexi was drilling holes...and ill work on resizing the pics
-morgan-
