my mobo plug area is loose
thenerd
the area where you plug in the ps/2, ethernet etc place. i currently do not have the shield on, and the mobo is tightly screwed onto case. when i try to plug something big in or out, like a printer cable, the damn thing just moves around due to the force i apply.
i have the asus a7n8x-e deluxe. does the sheild make a difference?
Yea it would make a difference, but as long as you are careful, very careful then you should be ok. Why don't you have one anyways?
