silentnswift
- Jul 18, 2005
My current computer specs are these:
Athlon XP 2400+
Soyo K7VTA Pro
Radeon 9200
512 133mhz SDRAM
40GB ATA100 HD
First of all, my motherboard doesnt even support an Athlon XP, it supports up to 1.33ghz Athlon (if i remember correctly). Dont ask me how my dad was able to get the Athlon XP to work. And supposebly, the 9200 is a horrible card and can't do crap, but somehow I am also able to run Half life 2 at 1024x768 Resolution, medium settings, and No AA or Ani, but good enough for me. Also, somehow all of this is running off a 200 Watt power supply that I got from my dads gateway Pentium 2 computer. And I think its time to upgrade my computer as hardware has advanced so much in the last 3 years. But seeing how NOTHING is going to be compatible whichever way I upgrade, I was going to ask you guys how I should upgrade next. I am on a strict budget as you can see by how cheap everything is above, so my next computer has got to have a lot of room to upgrade. I was thinking, is getting an Athlon 64 at around 3000+, an SLI motherboard, 512mb PC3200 RAM, and 1 6600GT a good idea? I was thinking that when I got some more money later, I could pop in another 6600GT, and upgrade to a Dual Core, possible some more memory. Is there any other way I can make the most out of my money?
Athlon XP 2400+
Soyo K7VTA Pro
Radeon 9200
512 133mhz SDRAM
40GB ATA100 HD
