my mini
LittleMe
Welp, I just got my mini in. It's my first mac and so far I'm loving the thing. Anybody use one to manage active directory? I'd like to move over to mac as my workstation for work (ofcourse faster than this mini) but is it possible? I've never looked into managing a windows/AD network with a mac. I'm well on the way to being a switcher, for the most part.
LittleMe said:
so no way to do it natively without using RD?
I'm not sure if VirtualPC instances can join a domain but if they can, you could run VPC with WinXP Workstation inside a VirtualPC instance on the Mac.
Nothing really native though, not that I am aware of anyway.
Thanks,
-Jeff
vpc can join domains...but i would reccomend using some sort of vnc solution. VNC has a nice cross platform ability from linux/unix/windows/mac...what have you.
The only flaw in this is that vnc is a potential security risk to be running on a server.
Which of course depends on whether your network is exposed to the internet or is strictly internal.
