SeegsElite
- Oct 6, 2007
UPDATED: (Check end of this post)
So, I've decided that I want to use my Desktop Tower for gaming purposes only and have a seperate computer for a dedicated HTPC. This rig will mostly be used for 720p/1080p x264 and Blu-ray discs
I've done my research and these pieces of hardware seem to fit my needs perfectly. They are cheap and powerful. Exactly what I was looking for. The small form factor will allow it to be portable. I have a bunch of friends with HDTV's and other HDTV's in my house.
All the items I'm in the process of buying at the moment. So far I have the motherboard and case bought. I will put in my final invoce to Newegg in the next couple of days to purchase the rest of the hardware. (I'm waiting for my next paycheck
) I'll post pictures of stuff when it arrives. Seeing how it's still the holidays, shipping times from UPS are horrendous. My 3 day shipping from UPS is going to take over a week. Items should arrive early next week.
PS. I'm thinking about getting an LCD screen to put in the 5.25" external drive slot. Any thoughts would be appreciated. Preferably something that also has a remote with it. I was looking at this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999166&Tpk=Silverstone LCD
If you guys know of something similar (and cheaper) let me know.
UPDATE:
Motherboard came today
Should be getting another package tommorow:
Moar Pics to come tomorrow!!
Motherboard:
JetWay JNC62K AM2+/AM2 NVIDIA GeForce 8200 Mini ITX AMD Motherboard - Retail
* With the nVidia GeForce 8200 chipset, I can achieve hardware acceleration for pretty much all HD codecs out there. (VC-1, MPEG2, h.264, x264 (up to L5.1))*
Mini-ITX Case:
Foxconn RS233 Black+Light Silver Steel Mini-ITX Tower Computer Case 150W Power Supply - Retail
*This case is small and sexy and the 150watt PSU included should be more than enough for what I need*
Heatsink/Fan:
SILVERSTONE NT07-AM2 80mm CPU Cooler - Retail
* I've read reviews that the stock heatsink/fan is loud. This was recommended by a friend who build a similar rig with the same motherboard and similar cpu.*
CPU:
AMD Athlon 64 X2 4400+ Brisbane 2.3GHz Socket AM2 65W Dual-Core Processor Model ADO4400IAA5DO - OEM
*This CPU could most likely handle most of the HD content itself, its very power for it's price (I know it's older)*
RAM:
GeIL 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model GX22GB6400LX
*The motherboard only has 1 DDR2 DIMM for RAM, and this 2GB stick should suffice for all my needs*
Harddrive:
Western Digital Caviar GP WD7500AACS 750GB
* I have a seperate machine with over 3 TB worth of storage, so I'll be swapping material on and off of this maching from time to time. 750GB should be plenty of room and I think that 1 drive should be enough*
UPDATE:
