My mini ITX gaming rig
nostylez
Edit.
Here's my rig guys, almost fully complete.
I've decided to keep my SSD in my laptop and waiting on a new one to ship.
I'm using an old SSD for now until the new one arrives.
So far, it's stock at a rock and I plan to keep it that way for now.
Hardware.
Case: Lian Li TU200
CPU: i5 3570k
Motherboard: Asrock Z77-ITX
Video Card: Nvidia GTX 680
Ram: Low profile Corsair Vengence 8GB 1600mhz
PSU: Silverston ST45SF 450watt
Storage: Western Digital Caviar Black 2TB
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
Shot at 2012-05-10
I would probably go with the Samsung low profile 1.35 volt ram, overclocks to 2200, will not interfere with any cooler upgrade. Samsung 2 x 4GB 1600 kit about $50.
Tomshardware did a comparison on some marvel SSDs, a Plexor 60 gb boot drive might be worthwhile, see article. About $70.
Looks good.
Overclocking to any great extent will require an aftermarket cooler, A good one that will fit an ITX board and case is difficult. Thermalright Samuel? CM GeminII S524 is too large (width wise).
Does the Chassis support a two slot video card?
Would a two slot card block access to motherboard plugs? Have to check that.
I dont know about that particular case but you could try a corsair hydro cooler. It may fit.
Thanks for the info,
I've already got a nice Samsung 830 256gb.
What I'm most worried about is aftermarket CPU cooler.
A gtx 580 fits from pictures I've seen so I'm sure the 680 would be no different.
Once I get parts I'll start sharing photos. Should be interesting putting the rig together seems it will be quite a bit of a puzzle.
I've just built my rig and will provide pictures.
As for cooling, I'm currently at stock. So far idle temps have been 35-38c which is quite a surprise.
Load temps I have not checked as I'm still setting up. I don't plan to overclock anytime soon, but if temps do get quite high I will opt to get better cooler.
