My Maxtor drives head keep resetting
yoyo13131
Ya Maxtor Drive( 80 gig) is less then a year old and every like 2 minutes I can hear my hard drive's head reset and my hole computer slows down for a little while. Are Maxtor drives suppose to do that? Becuase its really annoying listening to my drive make a werid noise every so often.
Is this just a falty drive or are maxtor drives suppose to do that? :confused:
I had a similar issue with one of my Maxtor HDDs (a 120 GB one). I used Maxtor's HDD diagnostic tool to fix it. No idea what was fixed, though.
1 - download and run Maxtor's diagnostic utility and pray that it fixes your problem.
2 - vow to never buy Maxtor HDDs again.
3 - profit!! :D
iirc, some say that this is due to heat, the head resetting. now i can not and have not had the chance to prove this. honestly, i have used all brands of hard drives and yet to have a problem with any of them. ice czar would be more knowledgable and be able to link you to the information.
3 - profit!! :D
But if you run a diagnostic utility doesnt that delete everything off of your hard drive? :confused:
did that actually fix it, i have 2 maxtor drives that do this, a 40gb and a 60gb.
yea, ill never by a maxtor drive ever again, they suck. ive had 6 go bad on me.
2x10gb
2x40gb
1x60gb
1x120gb
No, it doesn't.
It appears to have fixed it. The issue hasn't reappeared so far...
*keeps fingers crossed*
2x10gb
2x40gb
1x60gb
1x120gb
Over what kind of time period and out of how many HDDs?
this was across maybe 3 years, over a few different systems.
If the failure rate over such a time period is more than 20%, I'd definitely be looking at HDDs from a different manufacturer :)
Like Seagate! I have a 180 gig Seagate hard drive and it is so quite!!! and they have a 5 year warrenty! but they arnt cheap.
Seagate, Samsung, Hitachi. Any other brand is suspect at best ;)
