My Maximus Formula/E8400 OC...stable?
Mugen1516
The rig is in my sig.
1.325 vcore (set in bios). CPU-Z says 1.256 loaded or 1.288 idle vcore.
NB Voltage 1.51v (set in bios) Everest reads as 1.55v loaded/idle.
400 strap
Clock twister (asus specific setting) on "strong"
Everything else set on auto.
Temps look okay? Seems kind of warm but my room is warm too.
I keep itching to want to buy the X3350 or Q9450. But I know I probably won't seem enough difference to justify spending another $350 or so.
Would you call it stable?
Why blend? Try small FFTs and see what happens.
Blend is more prone to failing...It's hauling every components ass big time...If it passes blend, and you have patience to wait for blend, you got a stable balance system.
Small FFT's tax the CPU.
Just curious, Small FFTs is harder on the CPU OC overall.
