My label printer's shootin' blanks!
evildre
Hi, people. I have an Eltron Orion LP2443 printer. Yes, I know they're Zebra now. I have tried Zebra's driver and Seagull's driver, but to no avail. It sounds like it prints labels, and it spits out the correct number of labels, but they're all blank. I've cleaned the head, I've loaded new labels, but they're still blank. Any ideas?
Not even a single view? I figured with an amusing title like that at least somebody would have read this thread :D
Well the good part is that you won't have to worry about replacing the ink in a second printer ;)
I kinda understand your dilema. I have an Epson that worked great for about 2 years. I replaced the ink cartridges and now it prints all screwy, only some colors will print (different colors, different times) if at all. The funny thing is if I put in on my Apple, it will print a little better (ledgable) but still crap. I cleaned the heads with alcohol and looked all in it.
Oh wel, color Lasers are coming down in price :D
the only reason I looked is because of your title...
My initial thoughts: "Well stop jerking your cord so often!"
Anyway, if I were to troubleshoot:
1. Bad Media? (did you buy thermal media? does it darken when you put it next to a thermal source? DO you leave them in cold garage before use?)
2. Bad Connection (is this a USB printer, if so I would try a powered USB repeater to see if thats the problem, but I wouldn't think it the case since you are getting the correct number of lables "printed")
3. Bad Printer (Highest probability in my mind and you are pretty much SOL if this is the case, unless you have a warranty)
Thanks for replying, J-Mag :cool:
I've checked 1. The labels that I'm using are kept in a supply closet across the room from me. I work in an office environment, so they're at room temperature. I've looked up the model number of the label rolls I've been using, and they are intended for this particular printer. I'll put one next to a thermal source (the heater next to my desk) to see if the labels darken.
It's a parallel printer, but I doubt the connection's bad because it spits out the correct number of labels.
I'm inclined to believe #3 as well, because it's not working with different computers, different label rolls, etc. Definitely no warranty, as it's an Eltron, and I don't think anything with the Eltron name on it is covered by Zebra anymore. When the next purchasing meeting rolls around, I'll recommend that we get a new label printer (specifically, a Zebra LP2844, as that's what most of our customers use).
I've worked with the newer Zebras (QL 420) a little bit at work. I'm also guessing its the printer itself. Seems like its no longer heating the labels properly.
If you're going for somehting new, the ql 420s are kinda neat, they do wifi/bluetooth. We're using them with a custom app I wrote so you can print off barcodes using a wifi pocketpc->bluetooth->printer.
That sounds pretty damn cool :D
Most of our clients get the printer with the built-in print server. They tend to use it in a Citrix environment. Not too many of them have newer Zebras -- as I said, most have the LP2844 or LP2844-Z. Some are still running LP2443s, which is what I have. A few are using Z4M/Z4M Plus. I want to be able to create custom label formats that will work on most of their printers ... so I'll be testing on an LP2844.
Did you clean the print head? The 2844 and 2844-Z's need the print head cleaned periodically with an alcohol pad. Where I work we use them for printing labels for lab specimins. Aside from lusers spilling water in them, we've only had 2 that failed in the two years we've been using them.
Have you tried doing a regular text copy to the port? These types of label printers will print unformatted text with no trouble.
Is this a transfer or direct thermal model? If it won't print plain text, your print head is likely toast.. Almost cheaper to buy a used unit than replace the head if it's out of warranty.
