Lloydsword
- Jan 9, 2013
Hey guys i'm not sure my Processor is running correctly, i know little of these things and hoping someone could shed some light on the situation ..
the problems are the core speed only at 1500 and voltage at only .84 is this normal? thanx (heres the info)
CPU-Z
Binaries
CPU-Z version 1.63.0
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.313 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 3570K
Codename Ivy Bridge
Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1
Technology 22 nm
TDP Limit 77 Watts
Core Speed 1596.3 MHz
Multiplier x FSB 16.0 x 99.8 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 34x
Max turbo ratio 38x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 38x
Ratio 2 cores 38x
Ratio 3 cores 37x
Ratio 4 cores 36x
TSC 3392.3 MHz
APERF 2095.2 MHz
MPERF 3392.4 MHz
CPU-Z
Binaries
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Timers
Sys timer 1.000 KHz
Processor 1 ID = 0
Codename Ivy Bridge
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1
Technology 22 nm
TDP Limit 77 Watts
FID/VID Control yes
Max turbo ratio 38x
Min Power 60 Watts
O/C bins unlimited
Ratio 1 core 38x
Ratio 2 cores 38x
Ratio 3 cores 37x
Ratio 4 cores 36x
TSC 3392.3 MHz
APERF 2095.2 MHz
MPERF 3392.4 MHz
