My Imported PS2
Suscept
Hi,
Firstly, its JAP... i'm in UK
I have tried all connections my Tv has, Composite, Scart, RGB
Its still very choppy, the picture is not going to the edges of my widescreen, the rest of the picture is fine, no jumping or distortion.
This is not a game specific issue, as its like this in the menu system of the Ps2 also.
I'm thinking of buying a high quality ps2 av cable, but does anyone have any idea's as to how to fix it.
Just a guess, but you're using an NTSC-J console on presumably a PAL TV. If your TV is PAL... well, there you go.
I am wondering if this is because your running an NTSC device on a PAL tv? If so, you could try looking for converters.
Buying American wouldn't solve this issue =O
I was beaten to the post!
well i could go out and buy a new one, but this one was modded :)
So what converters are you talking about then?
You know you could softmod an Xbox in like 3 minutes right
You know he has a PLAYSTATION 2 right? :p
Anyways, try to hunt down a converter.
