Okay I have had this idea in my head for the perfect case for awhile but I decided to make a cruel MS Paint drawing, be forewarned as it is terrible. I'll try to explain it first.
The front of the case is 2x 80MM fans side by side as an intake. Below the fans is a slim dvd drive. In the rear of the case the mobo is lifted by higher standoffs so the optical drive can fit underneath. The case has a half height graphics slot. To the left of the motherboard is a psu something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16817104080
The case quality would be that of lian li with a thick aluminum and have a complete mesh front, mesh grating near the GPU, and above the CPU.
This idea would allow for taller coolers as nothing would be above it such as an optical drive, and the case length would only be the length of the PSU plus the thickness of the 80 MM fans. This would be a cool case with great air flow. Their would be 2x 2.5in drives to the left of the psu mounted vertically. The case would be about 8.5 x 8.5
What do you guys think?
