Anyways so this is my plan for my next build in case anyone is interested. The purpose of this is to give ideas to anyone out there looking to build a new system for when the next gen gear starts to hit. Hopefully I can also get a little bit of input from you guys. Perhaps you have something you can contribute to my build ideas.
I have always been about bigger=better, but I stumbled across a very interesting case that got me excited about building a new machine. Let me know what you think!
First off with this build being a SFF I have to begin with my case.
Here it is!
http://www.nzxt.com/products/rogue/
Next will be my motherboard.
Currently I cannot find any Do-It-Yourself mATX X38 motherboards available, but I will have one of these for sure.
For now I will use a place holder...
Next comes the CPU. On my current machine I use I was fortunate enough to find a seller on xtremesystems.org that had a QX6800 Engineering Sample for a great deal. More than likely I will not have the same luck twice so I think what I will do is get the new Q9450. If I am not mistaken it is Intel's new quad core that is clocked @ 2.67Ghz stock with 12MB L2 cache. I do know that these new 45nm CPU's overclock like beasts.
For the memory I may just get another 8GB of the stuff I am using now or just steal this stuff out of my current system and buy a 4GB kit or something for this older machine. This G.Skill memory is EXCELLENT. I can overclock this stuff in an 8GB configuration to PC2 9200 speeds on stock volts (2.1v). I see no reason to change unless DDR3 comes way down in price by the time I buy this machine.
Next will be the video card. I guess on this one we will all have to play it by ear. I'd love to get the nVidia D9E card and more than likely I will. Noone knows for sure if the D9E will be called the 9800GTX or whatever yet so I don't want to refer to it as the 9800GTX.
For my power supply I will get the 1000 Watt Ultra X3 Modular power supply. In testing this power supply is the most efficient power supply I have ever seen next to the PC Power & Cooling 1KW designs. The modular design will be VERY important to me inside this smaller case.
As for the monitor I will probably stick with my 42" Westinghouse cause it is just an amazing PC monitor. I have used Dell 30" LCD's and while they are very good they do not match the overall quality of this LCD. If you had told me this time last year that I would be using a HDTV as my computer monitor I would have laughed at you cause I believed that you could never beat the quality of a smaller regular sized computer LCD. Boy was I wrong.
The next part is my favorite part! The cooling! Feast your eyes on my watercooling kit I will use in this rig! This will be PERFECT for my overclocking needs and it will fit perfectly inside that monster of a SFF case!
Next comes the sound card! For this I am going to go with the AuzenTech Auzen X-Fi Prelude. If no other new cards come out from Creative this will certainly be my card of choice. Also I will be picking up some new gaming headphones that are a little less cumbersome than my Medusa's. I will get a pair of Sennheiser PC 350's. Currently these are brand new and not available anywhere in the US as far as I know, but gaming is very important to me and if I have to import them I will.
For the harddrives I have mixed feelings on them. I have been using Raptors in Raid 0 for quite a while. They are quite fast, but honestly not enough for me to really care about an extra second or so. Right now I am thinking I will go with 4 Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA and a single Raptor 150GB for my main HD that I will install Vista on. Then of course I will migrate over all my external HD's that I have. I should be kicking it with around 5TB's or so. That should be enough space to hold all my High Def material and music.
As far as DVD Burners and all that goes it is pretty much a gimme that I will have a really nice slot loading DVD Burner or two in there. I am not quite ready yet to jump on the HDDVD or Bluray train yet. Of course by January when this machine will be built that could all change.
I will have to get another Logitech G9 mouse and a nice Steelpad mousepad. For the keyboard I think I will go with another Saitek Eclipse II as they are fine keyboards.
All in all this looks to be a very sexy bastard if I do say so myself. I would appreciate any other ideas you may have!
Here it is!
