- Nov 11, 2012
I finally got an i9-14900K thanks to CaffeineMan
5/12/2026:
Replaced my capable overclocking i5-13600K with the i9-14900K. The motherboard is an ASUS TUF Gaming Z690-Plus WiFi D4 motherboard with the latest available BIOS (Version 4505). I kept it simple and had the CPU running at stock, and my memory running at XMP1 and Command Rate at "Real 1N". The memory is Crucial Pro DDR4 3200MT/s CL22 4x32GB for a total of 128GB.
For cooling, I'm using a DeepCool LD360mm AIO with a contact frame, and Thermal Grizzly Duronaut for the TiM. Temps so far at stock settings hasn't gone over 83C for the hottest core.
Geekbench 6:
Single Core: 3231
Multi Core: 16224
CPU-Z:
Single Core: 972.9
Multi Core: 16500.5
5/14/2026:
Lol, for some reason I thought it was the opposite, Gear1 for DDR5, and Gear2 for DDR4. I should probably stop listening to random search results.
I upped my DRAM voltage to 1.35V, Frequency to 3600MHz, Gear1, 18-22-22-42-2T. I left uncore on auto, but seen it hit 5000MHz during load and seen it downclock near idle. I'll try to hit 4000MHz.
I was not able to hit 3800MHz or 4000MHz. My scores were faster at BCLK 100:100 than 100:133. I also was stable at Command Rate 1T, but scores were better at 2T.
To be continued...
5/12/2026:
Geekbench 6:
Single Core: 3231
Multi Core: 16224
CPU-Z:
Single Core: 972.9
Multi Core: 16500.5
5/14/2026:
To be continued...
