BloodRedBath
- Oct 4, 2003
here is the deal....
I have TWO (2) NON-WORKING computers at the moment...
First you should know, i have 2 AMD computers. Relevent hardware is (1) of each of the following: 3200+ AthlonXP, Lanparty ultra B, 2800+ AthlonXP, and A7N8X-E Deluxe, first and second are a pair, third and last are a pair.
Second you should know, alls i did was take off the HSF, take out the processor GENTALLY, put in the processor GENTALLY, put on the HSF like any avg computer geek does....with ease
(hope everyone caught the joke but this time it actually went on smooth).
Third you should know, after i turned it on and got the results below VVVdownVVV, i put the CPU's in opposite motherboards and then BOTH didn't work.
Lastly i think you should know the results 'when i do what':
1) everything is step 'right' meaning the CPU's are in the opposite mobo's like i said, hsf on, thermal stuff there right, fan plugged in, ALLLL that is good. i push the button and the 6 or so fans come on "VRRRRMMMMMMMMM" lol... and the screen doesn't come up, the POST screen, the keyboard num/caps/scroll lock buttons dont blink 2 times like usual (meaning it's posting i believe), and i DONT hear any beeping of any kind.
So i make it so all that is in the system is the mobo + power supply.....no beeping even with no ram or video or CPU...
Same Shit Different Computers.
anything needed to be explained better just post here with your question - i'm a little tired atm so that might not be the easiest to read.
MUCH MUCH thanks to anyone's sane and non-stupid/pathetic advice.
